HobbyBoss 1/35 Soviet Cold War ASU-57 Assault Gun tiddler finished................
Dave Ward
This miniature 'tank' is finally finished
Not a bad model from HobbyBoss ( apart from the tiny bits ), but you feel that there wasn't enough data available for the interior, the driver has a pair of steering levers, and and instrument panel, and that's it. Same for the commander/gunners position. Externally, it looks pretty good. The AK decal solution had a bad effect on the decals, the right hand serial number began to shrivel & disintegrate.
Well, it will be a while before I attempt another tracked vehicle, with such tiny individual track links. Not only is it a matter of the size, but the fragility & tiny gluing areas.
Thanks for looking in.
Strange looking thing Dave. Tracks look really narrow and the gun barrel is long...
Nick
Good work Dave great subject ill have to mooch about and see if anybody does it in 72nd. Dave
Mr Lovell,
unless someone does a resin model in braille scale, then 1/35 is your only option!
Question: Are you a masochist????? ;)
