Home made Airfield display base
rickoshea52
To go with my A4 Skyhawk I thought I'd try my hand at making a small display base on which to pose it. Using a sheet of foamboard and a pack of Wills concrete sheets I have made a start on a lightweight and easy to make base. The Wills sheets were fixed to the foamboard with evil-stick and then sprayed with Railmatch concrete. I added a blob of Railmatch matt black and then sprayed along the panel lines and a general misting to subdue the cold tone of the plain concrete. When this has dried I'll add taxy way markings and parking stand numbers then complete with a strip of grassed area to add visual variety.
View attachment 64342View attachment 64343
Neat looking base rick . Its amazing the difference putting a model on a base makes , it really lifts it, and as you have shown it doesnt have to cost a lot to look superb , i think its really going to complement the skyhawk, cheers tony
Great idea Rick makes a lot of difference to a model to see it in its own surroundings.
Most of my stuff is WW11 & I put them on grass. Good contrast to the camouflage.
Also as Adrian is doing at the moment I dot ground staff around to give the model a sense of scale. Problem is getting ground staff for modern aircraft.
Found these figures but only 1/72
Combat Pilots (D/GB/USA) Modern (1/72)
[h=2]1/72 Scale Revell Germany Model Kit: 80-2402[/h]
Italeri also do 1/72 figures for modern scenes. Hasegawa have a 1/48 range for modern ground personnel, as do a few others. http://www.hasegawausa.com/figures.html
I got this finished earlier today. I painted the yellow lines after masking with tape with Railmatch faded yellow and used some spare locomotive decal sheet numbers for the parking stand. I could have gone further with other markings but I wanted to keep it fairly generic for use as a display for any smal aircraft. The strip of grass on the edge provides a bit of scenic relief. The concrete was gloss varnished then the decals applied before matt varnish to seal it. The varnish I used was from a couple of rattle cans that hadn't been used for a while and had gone off, but this has worked out ok with a fairly uneven surface finish so I'm not to bothered with the way it turned out.
In total I must have spent about £15 on materials, but this was for a six pack of foamboard and three packs of Will's concrete sheets so there is plenty more that can be knocked together.
View attachment 64461View attachment 64462
View attachment 64459 View attachment 64460
