OK, its wednesday which means silly question from Penny day (Actually you guys have turned all my silly questions into quite interesting threads)
So, Ive just found out the structure of an FS code.
For the benefit of reference to those that dont know here is a very very quick breakdown.
The FS is made up of 5 numbers as such
abccc
a Refers to the finish, i.e. Gloss, Matt, etc
b Is the basic colour, Reds, Browns, Yellows etc
ccc is the shade, the lower the number the darker it is.
Right. so looking ONLY at the last 3 digits, how much of a difference is there
For example, if you require xx100 and you only had xx090 is that "close enough". Thats 10 shades out.
How far out is too far out?
Does this vary from the seriousness of the modeller?
I suspect it caries also with the part you are painting?
I can imagine some people would say 1 shade is too much, beginners may be saying, well surely 50 shades wont make a difference for a cockpit?
The reason Im asking?
Im putting together what I believe will be the ULTIMATE paint conversion chart. Not only will it list the conversions, but it will also suggest close matches so that you can make an informed choice.
Here is an example
Lets say I require FS 34097 which Ive classified as "Matt Green, Very Dark 97"
This converts to Humbrol 30.
But, If you go 1 shade lighter, you get FS34096 (Matt Green Very Dark 96) which is Model Color 70.895 and Tamiya XF-61 (Some conversion charts claim AS-13 but surely that would be FS24097?)
In this above example we are talking 1 shade only, but if you are looking at, for example, a conversion chart, its very yes or no. There is no conversion from FS34097 to Model Color, but if you (I think its called this) fuzzy search, you get a very close match.
Anyway, once again, I waffle. So, how many shades of FS code would you say are acceptable on a "use at your own peril" suggestion?
abccc
Here is an example
