another luft '46 kit
what do you get for your £18-20?
well theres a box
a double sided sheet of instructions, construction on one side and paint suggestion on the other
a small sheet of very basic decals
i sprue of grey styrene parts with engraved detail
and one canopy
Construction starts as normal with the cockpit, very sparse, no detail on sidewalls and just a seat and joystick + pilot
Theres a little more detail in the engine
but one the body is fixed together all you can see of it is this
not much need for filler apart from the wing roots which i filled with squadron putty then smoothed over with acetone to lessen any sanding needed.
This is a pretty quick build with only 30 or so pieces making up the whole kit 6 of those are the engine.
I decided to go a little away from the instructions and add a little "individuality" to the paint scheme
but sticking with rlm colours for the camo, rlm 76 on the underside for instance
hopefully get the topside started tonight.
well theres a box
and one canopy
