For the markings, I need to mix and match things to come up with all I need. The main two problems are the number 5 on the sides of the turret of the monument tank and the star on the derelict tank’s engine deck. The former is distinctive enough in shape that I couldn’t use an existing number, so I made a stencil by tracing over a photo of the real thing in Adobe Illustrator and sizing it to fit the model. Though I could have used a decal for the latter, I decided to spray it too to avoid the edges and possible silvering of the decal. For that, I created another stencil in Illustrator, but the ring around it would be difficult because it was probably continuous. To solve that, I made two stencils: a star with an interrupted circle plus only the interrupted circle. The idea was then to spray the star first, and then remove the stencil and replace it by the circle stencil to fill in the gaps. I also had to put some thin strips of tape across the 5 to get it to lie flat enough on the turret. Here they all are:
After spraying the star:
Next, I put the other template on and sprayed again. Here already painted, because I forgot to take a photo before:
And with the second template removed:
That didn’t really go as well as intended
I didn’t line up the two templates properly and you can still see the gaps because the paint coverage depends on the number of layers. Also, I misjudged the amount of overspray, so there are two white spots on the sides of the engine deck.
Here is the other tank, where it went a bit better because of course I only had the one template to contend with:
I then touched things up, first by spraying some green over the white patches and then by hand-painting the gaps with more white:
The main lesson learned is that if I want to spray a star with circle again, I’ll cut a template for the full circle and the star out of tape or masking film so I can stick it down properly.
As I had the airbrush out anyway, I also sprayed the derelict tank’s tracks with Italeri Flat Rubber:
I did one of them in one piece, but that was just awkward so I split the other one more or less in half so the two pieces would fit into my paint booth with room to spare.
