I said I’d build the Italeri M113:
I get the impression this is an ex-Esci kit, but I’m not 100% certain. Here’s a sprue shot:
The kit has a partial interior, but is missing major parts. It has a floor, engine compartment firewalls, bench seats (but not backs) and commander’s seat and supporting pillar. What’s missing is the fuel tank, battery box, troop seat backs, radio shelves, and the whole driver’s compartment. Oh, and the inner roadwheel halves:
I have no idea why they omitted these, but if I had to guess, it was to keep costs down. From looking at another one of these kits I built a long time ago, though, it’s not a really noticeable problem once the tracks are on, so I decided to leave them like this.
This will be a Vietnam-era vehicle, and because I had a fair amount of epoxy putty left over from adding sand to my LVT(4), I put sandbags to the floor of this M113:
I made a fuel tank from more putty, given that I had it at hand anyway so I might as well not waste it. I took the dimensions (well, length) from a 1/35 example in my M113 spares box and just flattened the two visible faces; the top isn’t overly important because the roof will hide that. The bit of white plastic is a piece of 2 mm square rod to represent the battery box, again just a quick job to have someting visible through the rooftop hatch.
The driver’s seat is actually the commander’s,with the lower end of the pillar and the platform cut off. This bit of it will be visible through the rear hatch, if I keep the driver’s hatch closed
Chances are I’ll add an instrument panel etc. so I can have the hatch open, though. I could use the commander’s seat for this, by the way, because crews sometimes (often?) removed the whole thing. Same for the bench seats along the sides.
