Talk to AA....Bit much when manufacturers can't get it right, quick enough to take your money .
Great work on the cat walks.
No, the British version of those looked like this:ive never seen this on a sherman an is this a sherman that floats ?
There was indeed, lengths of T-profile along the whole length except where the fuel filler cap is. Resicast omitted that except at the front and rear, and they also left out the vertical parts of the T-profile, of course.Ref the catwalks, I would expect that there should have been a supporting length on the inner side to prevent the catwalk itself from collapsing or being bent out of shape
It does fit the three-piece nose, really. Not as well as it could perhaps, but I attribute that to resin shrinkage, which would give it a slightly smaller radius than it should have to fit properly.The Bumper looks like it does not fit any Sherman hull profile, how could they mess the fitting up?
I did wonder if I would have to build it that way, but really, all that was needed here was to cut off a triangular bit at the top, and then fill and redo the weld. It was easy enough to work out what to remove by holding the support to the side of the transmission housing.Would it not have been better for you to cut off the offending part and then add a piece of plasticard and then prifile it from one of your other Shemans and fit it that way.
Never seen that before. Strange thing.Or the American solution, the T6 flotation device:
No, I figured that doing that might mean the model won’t get finished before the year is out.That's a good solution for the tracks. You're not waiting on Gecko.
It was the American solution to making tanks float, but without the drawback of the British DD tank which couldn’t use its gun until ashore. They made similar things for the M18 76-mm gun motor carriage and, IIRC, even for the T26 heavy tank.Never seen that [T6] before. Strange thing.
It was in fairly limited use, mainly on the beach in Normandy but they did see use later on in and after the war, too. The Canadians built an equivalent on a Ram chassis and the Australians on an M3 medium tank, but both remained just as one-off prototypes, unlike the Sherman one of which something like a hundred were built. As I said in an earlier post, they were eventually replaced by a Centurion-based version:Having never heard of this version
Thanks. It’s quite an extensive conversion, but far less involved than you’d think at first sight. Mostly, it’s getting the superstructure to fit right, and after that most of the real work is in the splash plates and the catwalks. I had expected it to be more difficult to put together, really.it's impressive the amount of resin and PE available for this. Excellent conversion taking place here
Thanks, though making welds isn’t actually that difficult, if your putty cooperates, anywayyou have done some amazing stuff there. Making your own welds!! That's a new one I'll have to file away for the future.
