So, rolling my sleeves up to get stuck into the starter kit build with an Ebay special, the Westland Whirlwind.
Scalemates suggests this is a tooling from the late 70's, but the box is likely to be from the last 10 years so the paint has a hope of being as good as it ever was.
Unboxing shows a pretty simple kit, hopefully it'll go together nicely even if it's not going to have the detail of some of the newer tooled sets
Curve balls include a decal sheet which for reasons that I can only assume stem from a lack of confidence in the reds, requires me to put on the roundals and then the red dot in the centre
Anyway, it's a basic kit with basic tools, so may as well make a start, I'm going to have to paint the pilot up as "the office" is a step for a chair and a floor. Will see what I can do with the colours to hand, at least the kit has a choice of cheap brushes!
I do these things pretty infrequently and don't own an air brush so at least I won't miss that, but the choice of colours and lack of varnish and primer should keep things interesting
Jambo
Jambo
