I am about to add these (1/72), fairly lightly as in a newish plane with some service. (I have read that the outboard exhausts of the outboard engines do not produce streaks.) I have seen many photos of the original and models. The sort of effect that I aim for is that light grey streak produced by the lead in the fuel, with possibly narrow brown streaks. Acrylic paints.
My idea is to use an airbrush at low pressure aimed at right angles to the wing surface at the leading edge and as it is moved to the trailing edge, change the angle so that it is shallowly slanted along the surface. The idea here is to make the streak less obvious and feathery at the wing trailing edge.
Or would it be better to brush a streak and then immediately use a finger to smooth it out?
Any ideas? Thanks.
Any ideas? Thanks.
