Those pin vice drills are niceJust ordered a couple of things, not sure if I'll have much use for them, but cheap enough to sit and do nothing.
And a double of
Hi Mark,This has got to be the last one for the stash for a while :rolling::tongue-out3:View attachment 422525
yeah I might do,got some other stuff to finish first, then see if I can make my mind up what to pull out the stash next lolHi Mark,
That`s a cracking kit isn`t it?.... I bought one myself a short while ago,to replace a truck that i`d dropped,in my ongoing "Tonight,Long Stick Goes Boom" Dio....
https://www.scale-models.co.uk/threads/tonight-long-stick-goes-boom.36328/
I haven`t started it yet,but after looking at the sprues,i`m expecting good things:thumb2:,
Are you going to blog your build..... I,for one,will follow along if so!
Andy
Got an abundance of tools at work :thumb2: a hacksaw will do if you got a little vice to hold it.Good value, but you might have a bit of a job cutting through it!
Sidecutters - good quality ones will do the job, no problems, used to make all my own motorcycle cables when riding my custom bikesGood value, but you might have a bit of a job cutting through it!
You beat me to it. This is the best way I found to cut steel wire cable, everything else frayed the ends. (I gave up on using steel cable for tow cables on models, though.)Dremel mini-disc cutter - never fails, never frays - patience is a virtue though!
I'm with you on this Jakko, I think it's almost impossible to get the correct 'lay' of the cable even if you turn them yourself; in general I don't think metal cables sit naturally on the model unless CA is used at strategic points.You beat me to it. This is the best way I found to cut steel wire cable, everything else frayed the ends. (I gave up on using steel cable for tow cables on models, though.)
Rick. Yes I was a slave to Sleezbay last week on the “ Wingys” but like you there’s more on the way then I’m done. Well you know the story done for a while. LolWing Nut!!..........now yer getting them half a dozen at a time??......Yer almost as bad as me, just bought three more trucks and two trailers off Evilbay yesterday and waiting for the close of an auction on a bus and two more trucks on Tuesday. Better stock up on glue and paint while we're at it Lee......think we're gonna need it. :tongue-out3::tongue-out2::tongue-out:Rick H.
