Long haul Scania 143H Tractor build Part 1
\ said:
I have been working on the trailer for the Scania 142H long based chassi for some time now. So far this is where I am. I have finally added the side wind deflectors, which I painted black. I also toned down some of the weathering on the passenger side. Still have a little toning down near the windshield as well.
The trailer was scratch built and it is 90% complete. I have to add more details and a bit more subtle weathering around the trailer. I tried to make it look somewhat out dated by design but yet have a kinda modern feel to the rest of the overall look. I decided on the mix color combo; has the trailer, had been painted unprofessinally several times during its hard course life. Secondly, I wanted it to be different and stand out.
I am making the precast concrete slabs that will eventually be placed on the trailer when done..I am experimenting with various materials. The ones you see in the pics are made from posterboards. We will see what I end up using. The trailer has rest mounts for four precast slabs, which in turn can double up on each mount depending on thickness of the precast slab.
So I hope you like the trailer and the overall look of this tractor/trailer combo so far.
Trailer looks Fantastic, so life like.
John.
Appreciate the positive feedback fellas. Glad you like the results so far. Just got to do a little more work on details and minor weathering, then I will call it done.
Thanks Steve. Since these pics I have since moved the electrical box towards the front. The trailer legs have also been moved to the front, underside of the trailer. Apparently it made the trailer too wide. EU trailer regulation. I will post pics later when I have done the loads for it.
As I said before this this is blinking awesome. Really like the weathering you have achieved on this, the trailer only makes the whole vehicle look that much better
Really fantastic
Robert
Hi guys. Here are the some pics of what was done to the trailer since the last time I posted. As mention before, I had removed the electrical box and support stands to the front of the trailer. I also added a fire extinguisher. Instead of concrete slabs I decided to go with steel slabs, Only two. I think I will build a third sheet. Why steel? Well. I saw a haul with several large steel plates being transported in a similar manner and thought I would go for the 'not-so-normal' look, instead. You know me. Different is my middle name. I know there are standard trailers for concrete slabs and steel plates and slabs. But I found out that certain companies, in rare instances, use by any means necessary, quick and unconventional methods in transporting goods, if time was of an essence. I too have seen weird setups that just proves to me that transport methods do differ. Now, if they do not adhere to the EU regulation code; then that's another issue all together.
The sheet of steel were made from cardboard. The chain tensioners were scratch built. I am contemplating building another short base tractor 2x4 tractor for this trailer. I already have one in mind. Not too sure. But I will build it and see if it suits it better. If not, I will stick to the one I already have.
Yours certainly one to aspire too Charles your workmanship is just outstanding.
Thanks again gents. Much appreciated. Please let me know of the truck forum you mentioned. I probably might know it but just in case. Thanks.
Not on any of these anymore. I used to be on the IPMS and another one . I did dabble with trucks but I never really got into it. All I have in the stash now are a couple of the early Bedford trucks an a started Opal Blitz.
Must admit, when I used to be on the forums, there seemed to be a bit of a downturn in interest in the UK for truck building. I really hope that it does keep going. As can be seen by your great work, truck modelling has it all and there are some really talented modellers out there. Is it more popular in Sweden?
http://www.24thscalemodeltruckforum.co.uk
http://scalemodcommunity.info/phpBB3/viewforum.php?f=15
And of course, the IPMS UK board for trucks and commercial vehicles.
http://ipmsuk.proboards.com/board/113/commercial-vehicles-trucks-buses-trams
Yes. They are more truck builders this end. I am already a member on those forums you listed. Thanks.
I'm getting the hots for 1/24 heavy trucks. These forums look interesting. Thanks.
As superb as your Part 1 pics.
I am practising rust at the moment. Your convincing mottled look at bottom left of one of the steel plates is interesting (pic shown below). How did you get this effect (if its not a secret)? Sputtering with a stiff brush?
Sorry for the late reply. That mottled look was a result of the agents reacting to each other. After spraying the piece with matt varnish this random pattern appeared. I am working on a how to article on how i did these plates. I have gotten so many reponses asking how i achieved the look with cardboard. I have completed the text to the tutorial. Just need to do the process over with pics.
\ said:
Don't forget to share on here as well Steve ;)
Will do. I am still working on the tractor for this trailer, and later this will be put in a diorama.
YES! Please let us know.
Often its the reaction between coats that produces interesting effects. Looking at an old test piece (below), it has a reticulated look. I guess that the upper (green) coat was contracted in some way by the lower coat (rust red) while the upper coat was drying. The lower coat is Humbrol Clear Coat (a White Spirit based varnish) and the upper is Vallejo Model Color, which was applied after the lower coat was thoroughly dry. The reaction seems to have taken place when the upper coat, being wet, reacted with the lower coat.
The piece was a test of the salt method of showing rust. If the lower coat was some other colour this approach could be used for old peeling paint on a building.
