LUT 1/96
Eddiesolo
Nice idea haven't thought of that the actual lights used were large industrial 500 watt or more lamps housed in 3' diameter cone shaped housings on this scale the will be about 5mm across and 3 mm deep there are 6 to each arm assembly and they hung across the centre section of the arm so there going to be real pigs to model still trying to figure out what to use but fibre optics might work will have to investigate further on that here is a drawing I made of the sort of structure required
Regards
Colin
2mm lighthouse Led's maybe okay but having looked at them although they are round the have a square bit at the bottom. 3mm Led's is about the smallest you could do unless you go the fibre optic route.
that's a smart idea and eco friendly haha, nice job mate. The rest is looking good too
