Hi folks here is another offering from my work bench, it is Tamiya's 1/35 U.S Marine corps M60 A1 with reactive armour. This is an out of the box build using Tamiya paints oils and mig pigments, the colour scheme is a 50- 50 mix of XF 59 desert sand and XF57 buff. IT was highlighted by adding a small amount of white added to the base coat mix then dry brushed on.
I hope you like it and as always any and all comments are most welcome be they good or bad.
scott
scott
