Making a brick wall from Depron -Finished-
Richi72
Hi guy,s and girls,
After a couple of questions about the walls of my Dutch building, I thought, I would show you how I did that. There are definitely a lot of other ways like pouring them with plaster making them out of wood buying a model like the Miniart ones or Verlinden and so on, but I like to scratch so I make them myself.
If anyone like to join in please do, and don’t hesitate to ask any related questions.
I made a little template for a brick wall with a window and a door in it.
You can download it for A4 and US Letter size
So now to the what do I need question,
1. Piece of depron foam best is 6mm or blue foam or something that is equal to that.
2. Sharp knife or Scalpel
3. Some foam friendly glue
4. A ruler
5. adhesive tape
6. Some permanent markers with a small tip
7. Some paint, best is red for the bricks but any color will do
8. Plaster to make the mortar between the stones
That’s it
, and so we cut out the whole template.
here are the pictures
After printing out the templates we put them on the foam with some adhesive tape
then we take the scalpel and cut in the small side of the stones not to deep 1MM is enough
now we put the ruler on the long side and cut again 1MM deep
after a couple of lines it would look like this
and wen we are done this is what it should look like
after cutting the whole wall we take the marker and we start to draw each brick separately.
more later on
Cheers Richi
  • Brick wall Training US Letter format.pdf
  • Brick wall Training A4 Format.pdf
Part 2
after drawing each brick separately your wall should be looking something like this
here we can see the purpose of the marker we see a clear stone but none of them are the same accept for size
we cut the window and door pieces
when this is all done we cut out the door and window out of the wall
we glue the window and door pieces to the wall
then we use the marker again to define the stones (this time in Red)
when the glue has set we can paint everything orange it doesn’t have to be pretty and it doesn’t have to be all covered.
so the wall needs to dry for a while, so i will be back later
Cheers Richi
Part 3
After the paint is dry it would look something like this my orange is a little translucent but that’s fine.
Now we make a nice thin solution of plaster, it should have the consistency like a thin yogurt this is important because it has to flow a little
Here is the plaster on the wall; you can see that it is flowing a little so it can reach all the gabs
After a couple of minutes you take a sponge thingy and carefully wipe of the bricks don’t damage the plaster in the gabs. If you wipe the plaster out of the gabs you can put new plaster on it and try again.
Here are a couple of pictures with the plaster still wet. Because the plaster is a very thin solution (more water than usual) the plaster will sink in the gabs when it starts to dry, vaporizing water and so on but you know what I mean;).
Now we wait 2 to 3 hours until the plaster has dried and see what it looks like. :)
Cheers Richi
Excellent tutorial Richie.
Nicely laid out and great stage by stage description.
Thanks for taking the time to post the thread.
Ron
Hi Richi,
I agree with Mr Ron, I found this very easy to follow...
Thank you...
Andy...
Looks like a wall! Which is... I think... The general idea :) :)
Great tutorial Richi, nice and easy step-by-step to follow with an impressive result.
Hi Colin,
well I got the inspiration from you. :)
simple, easy to copy and great potential, learned that from your easy diorama setup.
So thank you
Cheers Richi
Part 4
After the drying period I should like this
Then we take an old big brush and we use it to dust the wall of and it will look like this
Now we have a couple of options the left side is dry brushed with red and orange tones the gabs between the stones stay mostly the color of the plaster you use.
The right side is completely painted this includes the gabs between the stones.
Then we take some dark red, blue, yellow and any other color you like.
We start to paint single bricks in a different color, it looks better and most of all more realistic
close up
close up
well now we wait until it is dry again
next up is blending and washing
cheers Richi
Some excellent tip there Richi, well done and thanks for that, a big help to others wanting to create walls, houses or any other structures.
Si:)
hi Richie
Fantastic and Excellent tutorial, well done with the step by step very clear and easy to follow
thank you so very much its rely appreciated
Part 5
Well the walls are dry and now we try the wash and blending trick
A wash,
is used to put a shadow or fill up deeper parts in a model that should seem darker than the rest of the surroundings, well with the wall we can use the washing to fill in the gabs between the stones but this time we use a bright wash to define those gabs between the stones. Because the wash is thin it wouldn’t affect the stones as much as a blending would so we can achieve a nice mortar color.
The Blending
Is used to make the different colors of an object seem closer to each other, more in the same color pallet or let it look if it’s all together. I hope you understand what I mean can’t find a real good description for it but if we take a look at the pictures I hope it becomes clear what I mean.
Here is the wall completely dry
Here we used a wash of yellow on the left side we can see how nice the gabs have been filed.
On the right side we used a cement color not as thin as the wash, to blend all the stones together and as you see it files up the gabs to, it makes a nice gray mortar color.
stil wet
Almost dry
in part 6 we will do some little dry brushing and then i think the wall is done.
until later
Cheers Richi
Thanks a lot Guy,s and Girls,
So here we go with Part 5 and it’s the last part to
These last pictures shows a little dry brushing with some red, orange and white
With the dry brushing u can define the stones a little more to get some more dimensions in the wall.
And this one is Cheers. I am gone take a coke now.
Not my best work but I hope it was understandable and clear what I meant.
Cheers Richi
Hi Richi,
This was brilliant and extremely helpful as well as very easy to follow, many thanks Sir...
Andy...
Thanks allot guy's
was lots of fun to, never done that, at least not for modeling.
so thanks again
Cheers Richi
