Has anyone got some tips on masking fuselage bands. I've already sprayed the area in white but now need to mask it off so I can spray the camo and underside . Obviously the cross section of the fuselage is not a perfect cylinder in cross section as is the case on the stuka I'm building. Not only does it taper but also the tail fin needs to be taken in to account. I've already tried to use very thin strips of tamiya tape but I seem to be struggling to get parallel lines.
Vaughan
Vaughan
