New from SMS Matho Models 1.5-3mm Photo-Etch Numbers 80006
Matho Models 1.5mm to 3mm Photo-Etch Numbers​
Matho Models 80006 is a detailed photo-etch sheet containing digits in four different heights. The sheet includes 1.5mm, 2mm, 2.5mm and 3mm numbers, providing a useful selection of sizes for adding precisely produced numerical details to scale modelling projects.
The photo-etch sheet has a thickness of 0.16mm and features extremely crisp, true-to-scale detail, including across the smallest numbers. Each digit height is listed on the sheet, making it straightforward to identify the different sizes and select the appropriate height for the intended design.
Four Photo-Etched Number Heights​
This Matho Models accessory provides digits in four clearly defined heights: 1.5mm, 2mm, 2.5mm and 3mm. Having four sizes together on one sheet gives you a choice of physical number heights while maintaining the same precisely photo-etched format.
The 0.16mm sheet thickness combines with the finely produced characters to create crisp numerical details. Even the smallest digits feature extremely clear definition and true-to-scale detailing, while the height markings on the sheet make the different sizes easy to distinguish before selecting the required numbers.
Suitable for All Scales​
The photo-etch number sheet is suitable for all scales, allowing the fixed digit heights to be selected according to the physical size required for an individual modelling project. The choice of four sizes from 1.5mm through to 3mm provides flexibility when different numerical dimensions are needed within a design.
With 1.5mm, 2mm, 2.5mm and 3mm digits together on a 0.16mm thick photo-etch sheet, Matho Models 80006 provides a clearly defined selection of small numbers. The combination of four identified heights and extremely crisp, true-to-scale detailing makes it straightforward to choose a consistent digit size and create the required numerical arrangement.
The post Matho Models 1.5-3mm Photo-Etch Numbers 80006 appeared first on Scale Model Shop.
