SMS Bot
Matho Models Cardboard Boxes – Post & Courier Services (1/35) 35074
Add realistic parcel and delivery details to your 1/35 scenes with Matho Models Cardboard Boxes – Post & Courier Services. The set includes 34 cardboard boxes in five different designs, providing plenty of individual boxes for creating varied arrangements.
Each box is printed on slightly thickened paper to give the assembled item a realistic appearance. The interiors are also printed with a brown cardboard texture, so the boxes can be displayed open or closed. This makes the set particularly useful for detailing scenes that require parcels, delivery boxes, and post or courier packaging.
With 34 boxes spread across five different designs, the set provides enough pieces to create anything from small groups of parcels to larger collections of post and courier boxes. The printed interiors add useful detail to open boxes, while closed examples can be mixed throughout the arrangement for additional variety.
For clean results, cut the boxes from the sheet using a sharp, preferably new, knife and a steel ruler. Also remove the thick white or black lines between the upper and lower flaps, as this helps the flaps fit together more cleanly during assembly.
After cutting around the complete outline of a box, make one cut to the left and another to the right of each thick line. Use the tip of the knife where the line remains attached and carefully remove the unwanted section.
For easier folding, use a knife and steel ruler to gently score the bending lines. Apply only light pressure so that these lines are not cut through. This creates neat, sharp bends and helps the box retain its intended shape during assembly.
Once a coloured box has been folded and glued together, exposed white paper edges can be lightly painted in an appropriate colour. This creates a cleaner finish while retaining the printed exterior design and brown cardboard-textured interior.
The post Matho Models Cardboard Boxes – Post & Courier Services (1/35) 35074 appeared first on Scale Model Shop.
Matho Models 1/35 Post & Courier Cardboard Boxes
34 Boxes in Five Designs
Cutting and Assembly
