New from SMS Matho Models Modern Soft Drink Logo Decals B 80021
Matho Models Modern Soft Drink Logo Waterslide Decals​
Matho Models 80021 provides an A6 sheet of waterslide decals featuring modern logos from popular soft drinks. Different sizes are included for each type of logo, providing a useful choice for adding recognisable modern soft drink branding to scale modelling projects. The decals are suitable for all scales, allowing the most appropriate logo size to be selected for the individual design.
The decals feature separated film, allowing each individual logo to come away one by one without the need to cut precisely to its edges. Their ultra-thin construction helps them adapt well to different surfaces, while the semi-matte finish provides a controlled appearance. High-definition printing produces crisp results even across the smallest details, with accurate and colourfast printing.
Modern Soft Drink Logos in Different Sizes​
The A6 sheet combines various modern soft drink logos, with each type available in different sizes. This selection makes the set suitable for a variety of scales and provides flexibility when choosing the required logo for a particular design. The combination of different sizes and modern branding makes this detailing set a versatile option wherever these soft drink markings are required.
Produced by Matho Models, the decals combine individually separated film with an ultra-thin format designed to adapt well to the application surface.
Applying the Waterslide Logo Decals​
Cut out the required decal with a sharp knife and place it in water for approximately 5 to 10 seconds to loosen it from the carrier paper. Gently slide the logo into position using tweezers. Decal softener, such as Micro Set and Sol, can be used for better adhesion, particularly when applying the decal to a non-flat surface.
Once positioned, use tissue paper and apply light pressure over the decal to remove excess water or decal softener and fix the logo in place. Varnish can then be airbrushed over the decal for protection. Semi-matte or matte varnish can be used to reduce glare if required, followed by the usual weathering process to blend the modern soft drink logo into the finished design.
The post Matho Models Modern Soft Drink Logo Decals B 80021 appeared first on Scale Model Shop.
