SMS Bot
Matho Models Oak Foliage (1/35) 35005
Add finely detailed oak foliage to your 1/35 modelling projects with this photo-etch accessory from Matho Models. The set contains one photo-etch fret of oak foliage, providing detailed foliage elements in a compact format for use within your chosen 1/35 project.
The complete fret measures 5.8 x 6.3 cm and includes oak foliage elements ready for use in your modelling work. The photo-etched format provides a practical way to introduce small-scale foliage detail where the distinctive appearance of oak leaves is required.
Oak foliage can provide an important natural detail within a model, and this set is produced specifically in 1/35 scale. The fret format keeps the individual foliage elements together until you are ready to work with them, making it easy to select and prepare the pieces you need for your project.
As part of the Matho Models range of photo-etch parts, this set concentrates specifically on oak foliage rather than combining unrelated accessories. This makes it a useful choice when oak foliage is the particular detail required for a 1/35 scene.
The oak foliage is supplied on a single photo-etch fret measuring 5.8 cm by 6.3 cm. Its compact size provides a focused selection of foliage elements while keeping the set entirely focused on this type of vegetation detail.
The 1/35 scale makes the foliage suitable for modelling projects at the same scale, allowing the oak elements to be incorporated alongside other details in the finished scene. Because the set represents foliage rather than a complete tree or plant, the individual photo-etched elements can be used as part of the modeller’s chosen arrangement.
With a dedicated 1/35 oak foliage fret, Matho Models 35005 offers a focused way to add fine vegetation detail where oak leaves are needed, with all foliage supplied on one 5.8 x 6.3 cm photo-etch fret.
The post Matho Models Oak Foliage (1/35) 35005 appeared first on Scale Model Shop.
Matho Models 1/35 Oak Foliage
Photo-Etched Oak Foliage
Compact 5.8 x 6.3 cm Fret
