New from SMS Matho Models PE Brass Strips 0.2-1mm x 0.10mm 80043
Matho Models Photo-Etched Brass Strips 0.2-1mm​
Matho Models 80043 provides a selection of photo-etched brass strips in ten different widths for scale modelling projects. The set contains one photo-etched fret with 25 individual strips, ranging from a fine 0.2mm through to 1mm wide. Every strip is 13.5cm long and has a consistent thickness of 0.10mm.
The widths are clearly listed on the fret, making it straightforward to identify and select the required strip. Suitable for all scales, the set combines multiple examples of each width in one convenient photo-etch parts fret.
Ten Brass Strip Widths​
The five finer widths are supplied with three strips of each size. These measure 0.2mm, 0.25mm, 0.3mm, 0.4mm and 0.5mm wide. The remaining five widths are supplied with two strips of each size, measuring 0.6mm, 0.7mm, 0.8mm, 0.9mm and 1mm wide.
This provides 25 brass strips in total, covering ten progressively sized widths. Each strip measures 13.5cm long, while the 0.10mm thickness remains consistent across the complete fret. The dimensions printed on the sheet make it easy to distinguish between the closely sized strips while working.
Photo-Etched Brass Suitable for All Scales​
These Matho Models brass strips are suitable for all scales, allowing the required width to be selected according to the individual modelling project. The combination of ten widths and multiple strips of each size provides a useful selection of 0.10mm thick photo-etched brass material on a single fret.
  • 1 photo-etched brass fret
  • 25 brass strips in total
  • 10 different widths from 0.2mm to 1mm
  • 3 strips each in 0.2mm, 0.25mm, 0.3mm, 0.4mm and 0.5mm widths
  • 2 strips each in 0.6mm, 0.7mm, 0.8mm, 0.9mm and 1mm widths
  • 0.10mm strip thickness
  • Each strip measures 13.5cm long
  • Suitable for all scales
Matho Models 80043 combines 25 clearly identified brass strips from 0.2mm to 1mm wide, all measuring 13.5cm long and 0.10mm thick.
The post Matho Models PE Brass Strips 0.2-1mm x 0.10mm 80043 appeared first on Scale Model Shop.
