SMS Bot
Matho Models Street Name Signs A – French (1/35) 35123
Matho Models Street Name Signs A – French is a sheet of detailed water-slide decals featuring various French street name signs. Designed in 1/35 scale, the decals provide crisp signage details for suitable scale modelling projects and can also be used with other scales where their size suits the subject.
The sheet measures approximately 6.1 x 9 cm and combines ultra-thin decal material with high-definition printing. This produces crisp results even in the smallest details, while accurate, colourfast colours and a semi-matte finish give the street name signs a clean appearance on the finished model or scene.
These water-slide decals use separated film, allowing individual signs to release one by one without the need to cut precisely around the printed edges. The ultra-thin decal material is designed to adapt well to different surfaces, making it a useful way to add fine French street name details to suitable modelling projects.
Cut out the required decal with a sharp knife and place it in water for approximately 5-10 seconds to loosen it from the carrier paper. Gently slide the decal into position using tweezers. Decal softener, such as Micro Set and Sol, can be used to improve adhesion, particularly when applying the decal to non-flat surfaces.
Once positioned, use tissue paper and apply light pressure over the decal to remove excess water or decal softener and fix it into place. After drying, an airbrushed coat of varnish can be applied for protection. A semi-matte or matte varnish can also reduce glare if required. The usual weathering process can then be used to blend the French street name signs naturally into the finished design.
Copyright markings are not present on the actual product.
The post Matho Models Street Name Signs A – French (1/35) 35123 appeared first on Scale Model Shop.
Matho Models French Street Name Sign Decals
Ultra-Thin Water-Slide Decals
- One sheet of French street name sign decals
- Designed in 1/35 scale
- Can also be used with other scales where appropriate
- Sheet size approximately 6.1 x 9 cm
- Separated film for individual decal release
- Ultra-thin decal material adapts well to different surfaces
- Semi-matte finish
- High-definition printing for crisp fine details
- Accurate, colourfast colours
How to Apply
