matt varnish help needed
Ive been using windsor & newton Galaria acrylic matt varnish and no matter how i brush it on it always seems to dry streaky.
any suggestions?
\ said:
Ive been using windsor & newton Galaria acrylic matt varnish and no matter how i brush it on it always seems to dry streaky.any suggestions?
What are you applying the Varnish to Wayne ie what type of paint ? Is the paint you are applying it to well cured as if it is not this is a good indication of your problems. Paint may feel dry but it needs to cure well.
I would try thinning it then try a practice piece.
Alternative try Vallejo.
applying it to acrylic thats had a coat of "future" using a smallish, soft brush.
I read the instructions and it says to just apply thin coats allowing 24 hours between coats but thats just not working for me :(
I may try thinning it as it seems quite a thick liquid when in the bottle, i have an old kit i use for practising things on.
Hi Wayne i have found Vallajo matt varnish excellent it can be mixed with water to thin and does not leave streaks even on klear.
scott
Hi wayne , i use the Galeria varnish with the airbrush and its brilliant , ive brushed it a few times too and youre right , sometimes it can get a bit streaky , but i found thinning it slightly with water and giving two coats (with at least a day in between ) its fine. Just be careful to avoid runs , use a wide flat brush if possible. cheers tony
i've done a couple of experiments with it last night, i'll see if it worked later, thanks.
I've tried loads of matt varnishes, none have been perfect, especially for figures where even a hint of gloss looks awful. The best by far has been Testors Dullcote
