I know how and what these are used for, but does anyone actually know just what these products are?
Zak there are a lot of different solutions on the market now to help place decals, yes you use warm water first but when you apply the decal it goes of really fast and that is where these solutions come into their own! I use decal soft and all it does is make the decal more workable, worth getting a bottle mate as it make the job a hell of a lot easier\ said:Dont want to sound daft here but is this whats used for applying decals nowadays ? I newly back into modelling and still use warm water in a bowl method, that I was taught as a child
Know it all Graham\ said:You still use water to separate the decals from the carrier paper Zak. I only use Micro Sol after the decal has been applied in the normal way and has been left to dry for a few minutes. Micro Sol basically partially melts the attached decal allowing it to settle into the surface detail. So if the decal goes over a panel line, the Micro Sol will make it sink into the panel line rather than bridging it.
It has to be applied with care using a soft brush without rubbing the decal as it will become soft and fragile. It will possibly wrinkle up as well but don't panic, it will settle down as it dries and pulls down.
Sorry Mark, I think we typed and posted at nearly the same time\ said:Know it all Graham![]()
I never let go of the decal for that very reason. I dunk in warm water but keep a grip on the thing with a pair of tweezers.\ said:Personally I've moved away from dunking decals in a bowl of water. I use a wet j cloth & place the decal onto it. It does the same job & there's no fishing around for a decal that doesn't want to leave the bowl!![]()
I'm not sure that Microset, the first part of the process, is necessary. It can make fragile decals difficult to work with too. I do use it nonetheless.\ said:I've never used either of these but I have used decal fix so is there any major advance in getting these two
Micro sol and micro set??
Honest opinions please
Regards
Robert
