Hi,
Normally when I've applied decals, a few years ago now, I would have just used warm water, positioned in place and dabbed with a soft cloth. Now I see things have changed since then with products like Microsol and Microset. Just how easy are they to use?
I did see a picture that Stona posted where the decal had nicely absorbed into the rivets and looked almost painted on. Am I right with thinking you soak the decal in warm water still, then use a squirt of Microsol where your positioning the decal and dab the decal dry with a cloth?
When the decals dry (how long, 10mins or next day?) you then put on Microset to soften. Do you dab it into the decal with a brush to push it into the contours and rivets or will the solution do this for you. Do you wipe it off or let it dry? Can it effect the paint if left on too long?
Also with the kit I'm building, the Tamiya Spitfire MkVb, it comes with white backing decals to place behind the RAF roundels. Where and when would you use Microsol/Microset with this decal set up?
Thanks,
Colin.
Thanks,
Colin.
