Follow me during the construction of a new model,the basis for the construction is the Westwings de Havilland DH.80A Puss Moth kit,no longer available unless you can find some old stock,Westwings are no longer in business having ceased production some years ago.
Lets take a look at what is in the box,if you want to take your model building skills a bit further then these models will give you plenty to create with your own hands,along the way I will be showing you ways of improving parts,which tools to use and above all making the most of these basic but adequate printwood kits.
The all important plan showing all aspects of the construction.
The printwood parts which are cut out with a craft knife,always use a new blade every new model they need to be sharp,XActo knives are ideal to do the job,cut out the parts over a few days doing a few at a time and store them during the build in flat card boxes.
More printwood,this is a very simple kit to build having basic fuselage sides.
The kit will contain carefully cut quality strip balsa,select which strips you need as you go along.
For gluing I use my favourite Aliphatic resin adhesive with a tube of balsa cement as well for nostalgic smell standby ! if you use balsa cement then always pre cement the joints first by smearing a bit on each half allowing to dry then re-coat for the final joint,this is because the cement sinks right into the grain of the balsa wood.
This is what we are aiming for a flying model of this beautiful vintage aeroplane.
