SMS Bot
Modelcraft Rivet Tool Set PRT1000
The Modelcraft Rivet Tool Set PRT1000 is an easy-to-use modelling tool designed for adding rivet detail and extra realism to scale models. Simply roll the appropriate rivet wheel across the model surface to mark a consistent line of rivet details, providing a straightforward way to enhance surface detailing.
The set combines a soft-grip #1 handle with nine different rivet wheels covering 1:35, 1:32, 1:48 and 1:72 scales. With three wheel sizes provided for each scale group, the modeller can select the appropriate option for the detail being created. It is a useful addition to a selection of chisels and carving tools when working on detailed scale modelling projects.
For 1:35 and 1:32 scale modelling, the set includes 0.85mm, 0.9mm and 1.0mm rivet wheels. The 1:48 scale selection consists of 0.5mm, 0.55mm and 0.6mm wheels, while the 1:72 scale selection provides 0.35mm, 0.4mm and 0.45mm wheels.
This choice of wheel sizes makes the tool suitable for adding rivet patterns at several commonly used modelling scales. The rolling method provides a quick and easy way to mark the model surface while adding the detailed appearance that rivets can bring to a finished project.
The supplied soft-grip #1 handle is designed to hold the rivet wheels during use. Alongside the handle and nine rivet wheels, the Modelcraft set includes storage cases, an Allen key and a wrench. This brings the supplied components together as a practical set for creating rivet surface detail.
As part of the Modelcraft range of modelling accessories, PRT1000 provides a simple method for enhancing model surfaces. Select the required rivet wheel, fit it to the soft-grip handle and roll it across the surface to mark the rivet detail. With dedicated wheel sizes for 1:32, 1:35, 1:48 and 1:72 scale work, the set provides nine options for creating detailed rivet patterns.
The post Modelcraft Rivet Tool Set PRT1000 appeared first on Scale Model Shop.
Modelcraft Rivet Tool Set for Scale Models
Nine Rivet Wheels for Popular Modelling Scales
Soft-Grip Handle and Useful Accessories
