Hi all have started collection the spitfire Mark 1A magazine, got issues one and two after brekkie will get issue three , going to be an expensive build, no painting, brings back memories of building a 24th Airfix spitfire yes did come with a motor, will have to track down the pic of me holding it , was 19 at the time .
The propeller blades are metal and same with nose cone , so far the motor housing the motor fits in is held by two screws, you can glue but I wont , very unusual them picking this scale, I
can't stop half way through very hard to get hold of a spitfire in that scale .
It wasn't easy to get the gears lined up right as you can change the pitch of the blades pure awesome, I hope the led wiring be easy to wire up they are for the guns, even the landing gear is powered that be fun , cockpit dash board lights up as well, .
Issue comes out every fortnight , not too bad, always being after a model that everything works
This weeks issue with needed parts , get the the first part of the fuselage., will need to do some gluing of the motor's pipes , seen the video on how to build it on spitfire model.com.
Tony from down under
