Hi, you've seen what it looks like made up so now you see what I went through getting it done. I have already mentioned how I liked these weird FAC planes of the Vietnam era so I was lucky to land an old Testors reboxed Italeri kit of the O-2A Skymaster. The box had seen better days and just as it was starting to disintegrate I decided to put it together. Lets start with the box...
Now the customary sprue shots. The sprue trees were missing and parts were swimming in the open plastic bag. I was fearing there would be missing parts.
Everything was there but the destruction sheet and one clear part. I wasn't too worried as the parts count was very small so finding where they should go and fit wasn't a problem. The missing clear part was a problem because it was for a curved area down the side of the fuselage. I'll come to that later.
One look and I knew the twin boom connection to the wing would need lots of filler and sanding. Rivets peppered the whole surface of the kit. I decided at this point to engrave the raised panel lines and sand down the rivets to be less prominent.
Apart from the brittle plastic, it was ready to build. Surgery starts next...
