New from SMS Mr Hobby Mr Weathering Brush Set Extra Small (Soft & Hard) MB-35
Mr Hobby Mr Weathering Brush Set – Extra Small Soft & Hard​
The Mr Hobby Mr Weathering Brush Set MB-35 contains two extra small brushes designed for applying weathering effects to small-scale figures and detailed models. The set includes one soft nylon brush and one hard hog hair brush, providing two different bristle textures and levels of firmness for working on smaller surfaces.
Weathering small figures requires control over where effects are applied and how they appear on the model. These extra small brushes are designed for working on fine details, with compact bristle heads that allow different weathering textures to be created within a limited area.
The two brushes have different bristle materials and characteristics, allowing modellers to vary their weathering technique according to the surface and the effect they want to produce.
Two Brushes with Different Bristle Characteristics​
The MB-35 set includes two brushes, each with a different bristle material and level of hardness.
  • Soft brush: Made with elastic nylon bristles, providing a softer brush texture for controlled weathering work.
  • Hard brush: Made with hog hair bristles, offering a firmer texture for creating different weathering effects.
Using brushes with different levels of firmness allows the appearance of weathering to be varied across a model. The soft and hard brushes provide different contact characteristics, helping produce changes in texture when working on small-scale figures and detailed components.
Extra Small Brush Dimensions​
Both brushes feature compact bristle heads intended for detailed weathering applications.
  • Brushes included: 2 (one soft and one hard).
  • Shaft length: Approximately 15.8cm, including rivet.
  • Bristle length: Approximately 3mm.
  • Bristle thickness: Approximately 2mm.
  • Soft brush material: Nylon.
  • Hard brush material: Hog hair.
The short bristle length and narrow brush heads make this set particularly suited to weathering smaller areas where a larger brush would be less practical.
Weathering Small-Scale Figures and Detailed Models​
The extra small size is intended for creating weathering effects on small-scale figures. The different bristle textures allow modellers to adjust how weathering is applied, using either the softer nylon brush or the firmer hog hair brush depending on the effect required.
These brushes are part of the Mr Hobby weathering brush range, which includes different sizes for different modelling applications. While the extra large version is intended for expressing dirt effects on larger military models, the MB-35 extra small set concentrates on finer weathering work.
With one soft nylon brush and one hard hog hair brush, the MB-35 set provides two distinct brush textures in a compact size for applying varied weathering effects to small-scale figures and detailed model surfaces.
The post Mr Hobby Mr Weathering Brush Set Extra Small (Soft & Hard) MB-35 appeared first on Scale Model Shop.
