My Centurion Mk11 diorama
Top job Malcolm!!
Looks very good, specially the base and vegetation.
The weathering and the mud is genial too.
I don't see very well....but one of them has a poker?!
Polux
I like this one a lot.
I have this tank on my to buy list. Its nice to see one built up.
Five more stars!!!!
what did you use for the trees and vegetation, top marks
Awesome. i like what you have done with the panzer crew playing cards.
Nicely set out malcolm, some great detailing and weathering in there.
superb dio as arron said nice conversion of the german troops playing poker...superb work buddy
I got lucky with this kit at the Hinckley show a few years ago.
I bought a Lottery ticket on the Saturday and got 4 numbers up and won £103.
The kit cost me £75 from a trader, nett cost to me in real terms was £1.
Phalinmegob, I used some twigs that I picked up on a trip to the local woods.
I drilled holes in the twigs and glued some `sea-foam in place.
When dry I used spray carpet glue sprayed onto the `trees` and, starting in the middle of the tree sprinkled my own mix onto it and when dry sealed it with some outside wall sealer from a spray can.
Over time they do fade a bit but a quick burst with a rattle can puts some colour back on them.
The `Mix` I use consists of various scatters, real herbs, small flakes of tobacco, tea leaves.
For the trees I add more herbs to give a more `leafy` look to the mix whereas I use less herbs for ground work.
Under the trees where dead leaves can be found I sprinkle tea leaves, tobacco which I got from my mates cigar stubs, which are crunched up to different sizes and dark scatters.
I also use a lot of real soil and sand in my ground work.
The plaster I use to make the basic shape of the ground is mixed up using water, PVA glue and paint to pre-colour it.
This paint, I get from DIY stores, it is the small tester pots that cost around a pound or two.
I find it simple and effective and above all a cheap way of creating ground work.
Malc.
Aaron, I`m currently working on a small dio of a Jeep in British service during the Suez crisis with another set of these figures converted to British Paratroops playing cards besides the Jeep.
They are a great set and only need the heads changing to suit just about any army if painted in the right colours.
