My questions - I did forewarn you!
1. What are the best collection of acrylic paints?
I currently use Revell and Humbrol enamels...but I'm not too shy of going to acrylic - are acrylics better than enamel? I have to say I love the smell of enamels (I'm not addicted, no)
2. I have the Micro Sol and Micro Set solutions for my decals and in order to apply them without "staining" I use Klear on my model...but this give's the model a sheen look. Is there anything else I could use? If I will always get the sheen regardless, is there another step I could perform to remove the sheen?
3. I have LOADS of questions on technique, but I'll read the appropriate thread first - or at least some of it
4. The big one.
I am thinking of moving to airbrush...but lots of things scare me
a) Mixing/thinning - I don't want to do this...can you use an airbrush without having to do either of these steps?
b) Cleaning - first off cleaning "the bowl". Obviously you put paint in there...when you are finished, how do you remove it? Is it wasted? Can it be re-used? And when you do remove what's left, how do you clean the cup?
c) Cleaning between coats - I presume this is required at least when switching colours?
d) I presume at the end of the session, you have to take the brush apart and clean it? Each time?
e) My wife doesn't understand the appeal - so I need to look for cheap quality. I realise these are probably a contradiction in terms...but at least mediocre beginner quality.
I was thinking of this airbrush
http://www.amazon.co.uk/Gravity-High-Precision-Action-Airbrush/dp/B003EJYY38/ref=sr_1_3?ie=UTF8&qid=1381914808&sr=8-3&keywords=badger+airbrush
And this tool for cleaning
http://www.amazon.co.uk/Professional-Airbrush-Cleaning-Station-Support/dp/B005DM37MI/ref=pd_bxgy_diy_img_z
Would I need these cleaning brushes?
http://www.amazon.co.uk/Precision-Nylon-Brush-Cleaning-Airbrushes/dp/B004GUN4Q2/ref=pd_bxgy_k_h_b_cs_img_y
And of course a compressor
http://www.amazon.co.uk/gp/product/B004XP7K9W/ref=s9_simh_se_p60_d0_i5?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=auto-no-results-center-1&pf_rd_r=010FN4ZSJYXQ3DWQD7YH&pf_rd_t=301&pf_rd_p=240112507&pf_rd_i=ASIN%3AB00AK889LY
The compressor does come with a couple of airbrushes but I prefer the idea of gravity fed (any reasons why gravity fed is better/worse than bottom fed?)
Also, although the compressor looks quite big (bigger than I had hoped) I think that compressor comes with an air tank which I heard was a good thing because it maximises air stability through the brush? But I don't see any mention of a moisture tank...
Essentially if I do go airbrush (I'm getting a bit fed up of going to use a paint only to find it's dried up!) I'm looking to spend no more than £100 maximum on the setup - though lower would be better. (like I said - she doesn't understand!)
Anyway - I think those will do for now.
Thanks
Billy
I too am still a brush man and just starting to get in to AB. I needed something small, space is limited and have a small compressor, this may not be ideal but for a starter kit it is ideal, gives good flow, which is adjustable, only fires up when needed, doesn't take up much room. Paints can be bought pre-mixed so you just add to your cup and off you go. I use AB cleaner and just add some to the cup and then add the AB to a cleaning bowl and clean through, also do this when changing colours, just make sure you you use all cleaner and test before you start spraying as you don't want cleaner on your model.
Any unused paint in your cup can be poured back into the original container, any paints you have mixed can be stored in a empty bottle with a lid, you can buy small bottles for this purpose until you use up paints, clean out the bottle and then use that for storage.
The pics show my kit, cost around £45. It may not be the best but to get to grips with it seems okay.
Si:)
Can't help with airbrushes as I use just a paint brush. I find Vallejo Model Colour Acrylics are way better than any other....Avoid Tamiya acrylics for brush work.
You will be getting loads of advise on your other questions toot sweet, fear not!
Ron
This will be fun! I am an enamel user so that will colour my answers....slightly.
1 If you have enamel paints and are happy using them why change? You will add a further complication to your move to airbrushing. I think that there is a good consensus here that Vallejo make some very good acrylic paints but you might need to find what suits you.
2 Most of us apply some sort of gloss coat (I use Klear like you) before decals. Once your decals have dried and you are happy with the model you can apply a further coat of varnish to give the finish you want, usually matt.
3 I think it was 42 :)
4a Some of the Vallejo acrylics like the Modelair range come thinned for airbrushing but some will still need "adjustment". Most other acrylics and enamels need thinning for spraying. Don't be worried about this. Enamels are MUCH more tolerant of approximate thinning. I thin in the paint cup by adding drops of white spirits to my Humbrol and White Ensign enamels.
b You will lose the excess paint in the bowl. If it has been thinned it should never be returned to the bottle/tin. You will get quite good at estimating how much you need and will be able to minimise this most of the time.
To clean the bowl I squirt in some thinners, spray about half through and then wipe out the bowl with a kitchen roll. Next I fill the bowl again, remove the needle, spray half through, back flush (by blocking the nozzle) and wipe the bowl again. Finally I fill the bowl a third time, re-insert the needle and spray through....Done.
c As above
d As above.
Sometimes I don't completely strip and deep clean an airbrush for months, usually if it starts misbehaving. I believe this is another advantage of using enamel paints. I've had a couple of my airbrushes for more years than I care to remember. I have replaced the occasional nozzle, needle or seal and they work as well today as when they were new.
e Explain to SWMBO that when modelling she knows where you are and what you are up to :) There are FAR more expensive hobbies you could take up :) A friend of mine used to race hydroplanes and it just about bankrupted him!
An airbrush/compressor set up is a big investment (for most people at least) but it is a one off which should work for many years. Buy the best you can, I know that's easier to type than do.
Some of the other fellas may be able to comment on those options.
I hope you get it sorted, don't forget to show us some results and......enjoy.
On c and d (using acrylic paint): in my 9 months of airbrushing I have seldom needed to change paint during a spraying session, but when I do, I flush out with airbrush cleaner until no colour comes out, and brush the nozzle with a soft brush loaded with cleaner and wipe with a paper towel.
During a spraying session I brush the nozzle every few minutes, as above, to avoid flakes joining the paint stream.
After a session, I always thoroughly clean the AB (0.4 mm needle size). I wipe the needle in a cleaner-soaked paper towel. Then I disassemble the nozzle parts and soak them for about 5 minutes in AB cleaner while I use the supplied bottle brush (soaked in cleaner) to clean the passage between the nozzle area and back towards the trigger, but not into the seal (Harder and Steenbeck advise not to do that because it tends to wear the seal) until drying the brush on a paper towel shows no more colour (difficult with clear varnish).
Then I use an inter-dental brush (from Boots etc.) to clean the nozzle, and other brushes to clean the other two nozzle parts. I inspect all brushes for hairs and remove them. Now and again, esp. if I have had a serious blockage, I take the trigger out and clean that and its seat within the AB. I then usually put all parts into my little ultrasound cleaner which often loosens tiny specks which can be seen in the water. Despite that, I sometimes (perhaps once avery 10 sessions) get a blockage and have to abandon the session while I re-clean. I am particular to avoid flakes of dried paint getting into the AB. For example, I always wipe the spout of Vallejo bottles (and the top of other paint bottles) before and after using, and always replace the cap immediately. Despite my Aberdeen ancestry I throw financial caution to the wind and bin painty paper towels early, well before they run the risk of depositing flakes. The cup needs thorough cleaning because of the flakes problem.
I do all disassembly and re-assembly over (literally over) a small tray placed well away from the table edge, with by stomach pressed hard up against the table so that I work over the tray. Nozzle parts are expensive and once dropped are eaten by the carpet monster.
Obsessive? Well, yes. I am that way inclined. "Prevention is better than cure". Being retired I have lots of time. When I started spraying in February I got lots of inexplicable and frustrating blockages (which sometimes can be blown out at high air pressure (50 PSI) and lots of trigger.
I can now reliably get an even coat of paint which looks pretty well up to the standards I see at shows. Clear gloss varnish is tricky which I use before decalling, as per the rules to avoid silvering.
I see that Steve (Stona) does such deep cleaning only now and again. Perhaps enamel paints are more forgiving (acrylic paints dry in a flash, mostly a great advantage).
Its useful to know what other people do and as a near-beginner I have found that very useful (thanks folks), but personal experimenting is the key to getting things right (and the ability to press on after a disappointment).
(Must have a coffee after all that.)
Lots of help there thank you.
@eddiesolo - there are no problems with you using such a "basic" compressor? I thought an air tank and a moisture collector were must haves to keep the stream of air and paint constant and to remove any moisture from the air before it is fired with the paint? Maybe it depends on how long you are using it? Anyone else know if a tank and moisture collector are required?
Also - I'm interested in that blue mech you have on your airbrush...I always thought it looked kind of fiddly to operate the airbrush with that wee trigger up top...so is that mech to make that a bit more "easy feel"?
@stona - I was thinking about changing to acrylics for 4 reasons
1. quickness of drying...enamels take a considerable amount of time
2. cleaning - this only really applies if I was to move to airbrushes, but water is cheaper and in more abundance than white spirit :-) and given the amount you suggest cleaning - that's going to build up to a considerable amount of cleaner (I would think)
3. Viscosity - again only applies really to an airbrush but I worry about the viscosity of enamels on an airbrush
4. Life - sometimes no matter how much I make sure that enamel tin is sealed, I'll go to use a paint I don't often use (often for little cockpit bits and the like) and it's solid
As for using Klear - do you apply with the airbrush? I find with a normal brush it often bubbles
Thanks for the replies.
Some more points asked by Billy (wmar1967):
Thinning: I was rather obsessive about thinning (I use Vallejo model Air paints) but now just do what others advised, thin (preferably with the company's own thinner), to the consistency of milk about 10% (9 drops of the Vallejo + 1 drop of thinner from a plastic pipette, but Vallejo say that thinning of Model Air is unecessary. The amount of thinning seems not to be critical.
Cleaning Station: I have the cleaning station you listed, just to hold the airbrush and to contain initial test spraying. It came with my compressor bundle. But be careful not to bash the needle's point when putting the AB into the rest. One of those two-pronged nozzle protectors are useful and still allow wiping of the needle during a session.
Tiny Bottle Brushes. I find these indispensable. I avoided the ones with metal hairs, they could wear the AB.
Gravity Feed. My AB is gravity feed (cup on top). A lot of advice here is to go for that rather than bottom feed because gravity helps the paint to flow down into the nozzle, whereas with the bottom cup the air pressure (so I was told) needs to be higher to suck the paint upwards. I think people go for bottom feed for nail art, body painting, guitar decoration etc. (the bottle being bigger than most cups).
Thanks alot.
@Stevekir - there certainly seems to be more cleaning required than with a brush!
The whole idea of possibly moving to an airbrush is I prefer the finish. I can see when I've been making models that I will likely still be using brushes...
One last question I think (for now). What size needles would I require? I gather from 0.2 to 0.5? Bearing in mind I work on 1/48 aircraft and 1/35 vehicles - and I have been eyeing a couple of 1/32 aircraft
thanks again
Hi Billy, my set up comes with a moisture trap, it just isn't fitted on these pictures. The rule of what you pay for does apply and if you can afford better equipment then that is fine, however, on a budget this works okay to get you started, and as I said, it is small enough to cart around, set up and use. I tend to use mine for detailing work , as I still use rattle-cans etc for main coverage but I do intend to use this to practise on and sharpen my skills then maybe upgrade to a larger set up. The blue part is just a handle, I have a disability that means that mu fingers and hands cramp so holding it and operating the top trigger can cause issues-I drop the blighter lol. This just allows me to hold onto it lighter and can rest more, gives me a bit more stability.
Si:)
Best collection of paints do not know as I only use Vallejo mostly model air. It does the trick for me & has so many colours & a vast array of bits & pieces. Acrylic. Cannot stand the enamel smell & living in a flat it is not acceptable plus a minor thing I hate enamels to work with.
Decals. As a base I use Vallejo gloss Varnish. But ! Just had a dabble with Humbrol Clear (obviously a play on Klear) & it is remarkable. Try it.
Air brush one no you can not. Vallejo Model Air though is easy. Pour in to the pot approx (depends on the paint colour) 20% thinners. Pour paint into the pot on the top of the thinners. Mix with a brush in the pot. Mixing paints. The Vallejo containers have a dropper top. 5 drops of say red 2 drops of white mix with brush in the pot. Unused paint in the pot squeeze the air out of the container place dropper in the paint release and the residue is sucked back.
Cleaning an airbrush. I use mostly water. Harder & Steinbeck air brush. Dismantle wash all parts in water (using acrylics) place nozzle in airbrush cleaner reassemble 4 minutes. Changing colour in a session. Spurt through a couple of pots full of water half a pot of airbrush cleaner & all ready for paint. Some only clean assembled I prefer in 4 mins to clean disassembled.
I would recommend gravity feed & dual action airbrush (tried the other type in my opinion they are not suitable for model making). I would go for Harder & Steinbeck or Iwata. You can get good deals on these. Tried Badger!!!!!!!!. If it is finance go as said for the the H & S or Iwata as a cheaper brush will not have the quality in engineering & hence in what you can do with the brush. But then many will dispute that. All I can say is that I have been through the mill & spent money (thrown it away) on poor quality in the belief that I am going to get quality & satisfaction.
Compressor is better with a tank. Again had both so I think the tank makes for a better more consistent finish.
Another way of looking at this. If you like airbrushing then an airbrush will last you for ever. With an H & S & Iwata all parts are replaceable on average not with a cheapo. I f you do not like it put it on Ebay & you will get a sizeable chunk of your money back.
Lastly do not worry about the paint you are to use as 99% of paints will airbrush & you can try them to find the one that suits you.
Thanks eddiesolo
It just looks so small compared to the others I've seen...and in fact I've never seen a compressor in all the links I've visited like that one. What about not having any "stabilising" feet? Isn't that an issue? (I guess not on your quilt) :-)
For model paints your nozzle range of 0.2-0.5 is about right. The smallest I use is 0.3 an I make mostly aircraft from 1/72 to 1/32.
0.2mm is pushing towards the limits of what will work smoothly with typical model paints.
Laurie, I think the extra cleaning needed for acrylics is indeed due to the speed at which they dry. As you know I did switch to acrylics myself for a couple of years, so I do have some experience with them. I found that they dried to a hard skin both inside the paint cup and nozzle/needle assembly and this took some shifting. Enamels don't dry anywhere near as quickly (he said stating the bleeding obvious) so I find, for example, I can withdraw a needle and give it a quick wipe to clean it, same for a paint cup.
I think I sound like I'm "knocking" acrylics which is not my intention at all. I just want to share my experience of both. There are many very good reasons to use acrylic rather than enamel paints, some of which Billy has already mentioned.
In the end it's just a matter of finding what works best for you.
Everyone, including me, recommends a compressor with an air tank (reservoir). There is a good reason for this, it ensures an even flow of air to the airbrush. The first compressor I ever had did not have a reservoir and the pulsing of the air could be felt on the hand at the end of the hose with the brush disconnected. It still worked pretty well for a few years before expiring in a puff of blue smoke :)
Thank you.
For those that use enamels, another 5 questions!
1. What is the best/most comprehensive range you use? I've always used Humbrol and sometimes Revell
2. Where's the best shop to get all your modelling paints...using Amazon often turns out expensive in postage!
3. How do you stop the tins that aren't used so often from drying out/forming a rubbery layer on top
4. How do you know the consistency/mix ratio for enamel to thinners?
5. Do you use white spirits or thinners (for cleaning and thinning)?
I am really done now today - thank you all for taking the time to answer. You've likely all replied to these questions a thousand times before.
As I think Steve we have all said from time to time to time suck it & see & take your choice. They all have their plus marks & their downsides. In the end it is the one you accept as good for the finished article in conjunction with putting up with the disadvantages which each has in its wake. I moved from enamels to acrylics after my very personal summing up summing up.
On acrylics yes they do go off quicker than. Mostly the acrylic paint removes with a sharp water spurt. Failing that place water in the cup move a finger around the cup & 90% of the time it cleaned. Any remainder a spot of Vallejo Airbrush cleaner on a tissue clears with a quick wipe around but that is rare. Not had any problems with dried acrylics in the paint channel or nozzle. Sometimes a small dried spot on the needle which a comes off easily using two finger dragged towards the point {essential}. Should point out this is using Vallejo. Not sure of the properties of other makes. Used Revel for a very short time but I had many blockages but found it good for hand brushing.
Essential for acrylic clean straight after a session! But if you forget place bits in Vallejo Cleaner & it will soften to remove easily up to about 12 hours after.
[quote name=wmar1967
' date=' post: 180294, member: 24273]Thank you.
1 You've already got Humbrol. They have a good range and with the return of manufacturing to the UK the recent quality issues will hopefully improve. For specialist colours I use White Ensign Colourcoats. I can't praise these highly enough. They are the best paints of any type that I have used.
2 You can order Humbrol paints from the Humbrol web site or try other on line model shops that stock them, you might save a bob or two.
The Colourcoats I order directly from White Ensign.
https://www.whiteensignmodels.com/c/Colourcoats Paint/640/1/
3 Good housekeeping! You must clean the top of the tinlet and lid (if necessary) before putting the lid back on. Make sure you really push the lid on to make an airtight seal. I have some paints still useable after several years.
4 This is tricky and you will really need to experiment to find out what works for you and your set up. Different paints, even from the same manufacturer, also vary. Most enamels will fall in the range of 60/40 to 40/60 paint to thinners. That equates to about 50/50 on average. You will often see people suggesting the consistency of milk which is also a bit vague. Another tip is to drag some paint up the side of the cup with a cocktail stick or brush handle, it should run back but coat the cup.
There is I'm afraid no substitute for practice, however, in my experience enamels can be thinned a lot more approximately than acrylics. That is they will spray and work well in a larger window.
5 I use white spirits for thinning and cleaning. My current bottle is from Wicks (£3.75 for 2l which will last ages). I do use cellulose thinners from Halfords for deep cleaning but this is not suitable for all airbrushes.
\ said:
Thanks alot.@Stevekir - there certainly seems to be more cleaning required than with a brush!
Yes, definitely. But not all airbrush users are as obsessive as I am. Start with a middling effort on cleaning and see how you go.
I mainly use Tamiya acrylics, if they don't do the exact colour I want I sometimes go off beat and buy the odd pot of another make, if I need it though I can mix it.
I thin the paints by eye, roughly to a milk consistency with 99% alcohol.
To clean my airbrush I use concentrated car windscreen wash. I make on average one model month and have so far this year stripped my brush once to clean with airbrush cleaner, tbh stripping it every time you use it seems over the top to me.
I only use Klear for canopies and brush it on, for the model body I use Humbrol Acrylic Gloss clear, apply my decals and cover again with the gloss, wait 24 hours and then use Tamiya Flat clear spray if a matt finish is required.
Don't try to copy someones way to spray, we all hold and use the airbrush differently so just practice, practice practice. By all means watch the videos on Utube to gain an idea but go with what works for you.
My last point,,,, have fun and if you like it that's all that matters !
Adrian
Thanks a lot people. Lots of great info here...really - thank you.
I think I'll stay with enamels and if I go to an airbrush, see how I go. I love working with enamels - I like how they apply and as I said, it invokes strong memories from my youth with my dad.
One last thing - and this might be a hot topic - why in god's name do model kit manufacturers not list Humbrol, Vallejo, Tamiya and Revell colours for people to make the right call with a model. I'm having a hell of a time picking colours for my recent model - a Hasegawa Arado Ar234B-2/N Nachtigall
Anyway - thanks a bunch.
Just seen that White Ensign do colours that make sense. I may be making more purchases from them...thank you
