Billy there are conversion info sheets. Vallejo do their own with most manufacturers equivalents. Put model paint conversion into your search negine & it will come up with a good number.
Billy, just give thinning (not too much) a go on a test piece or the underside of a model, you'll be surprised how much easier it is to get a good, even surface. The lads on here who use brushes only, produce stuff that is on a par with a.b's.! So go for it!\ said:Thank you. Good tip on the paint pot.I never thin paint, however I sometimes do more than two coats
Nope! I've seen what you and others can achieve brush painting. It can be done. It's one thing that enamels do have an edge over most acrylics in. Despite airbrushing most of my models I still paint details or figures with a hairy stick and can achieve a reasonable result.\ said:Tin hats on everyone............Incoming!!
For smaller surfaces when you want a really nice gloss I still prefer enamels. I usually use a new brush though and a new tin of paint to ensure there are no bits of dust or dirt in it and then paint it with smooth gentle strokes overlapping as you would with nail varnish. I always used to do motorcycle tanks and mudguards in this way and I've never been able to better the finish with an airbrush. Mind you that's probably as I've never been any good with an airbrush!!\ said:I rally do like enamels and I'm going to stay with them - at least for brushing. I'll have to see how it pans out if I move to airbrushing.I think I need to take better care of the tins though so there is no air allowed in
Had me worried too Steve, but as I don't use nail varnish, I'm safe.....Mind you, the way things are going in this world, it will probably become compulsory before much longer!!!\ said:This is worrying knowledge Richard![]()
.......but quite right too.Cheers
You mean it's not compulsory now??. No wonder I get stared at\ said:Had me worried too Steve, but as I don't use nail varnish, I'm safe.....Mind you, the way things are going in this world, it will probably become compulsory before much longer!!!
Hi Aaron, I do use a primer under my enamels but I know many who don't. Enamels do adhere to plastic quite well it seems. I use a primer to serve as a light filler coat and invariably rub it back slightly with a very fine wet 'n' dry before applying the enamels. The primer coat also tends to show up any "nasties" in the surface or joins that I might have missed.\ said:.If your switching from enamels please use primer and renember more thin coats are better than a thick coat.
Don't worry Steve I only do my toe nails!\ said:This is worrying knowledge Richard![]()
