Hi all
yesterday evening I built the tank. A simple kit which goes together reasonably easy. like the male version it's a basic model, if I wanted to build a model of the tank as a project I would not choose this one, but for my purposes it will do fine.
i also put the five figures together - straightforward, the parts fit very nicely with only minimal filler.
that was yesterday evening, since the weather was bad today I decided to work out the layout of the dio. I still have some
resin sandbag sections from my earlier WW1 dio so used those with roofing insulation off-cuts to build up the ground to the level of the top of the sandbags.
Using various blocks and stuff to hold the elements at near enough the right height I produced version one:
here yo can see the initial layout - the French figures going around an abandoned tank. The lengths of mdf are to roughly frame the area of the dio.
Ok but not quite right - the trench did not seem to be fully integrated into the scene, and how would they cross the trench?
So, here is version 2:
Slight change - some of the soldiers advancing along a supply trench, there will be a ladder at the end of it and I may try to convert one of my unused French sodiers to be climbing the ladder. again, the mdf delineates the dio.
in the photo below I have started to cut the insulation board to shaope, which starts to give a much better idea of the layout.
Next photo and more of thr elements have been cut to shape and size:
The photo above also shows a couple of design changes: firstly, the supply trench has changed from having sandbags for its whole height, I am going to panel the lower part in the "wicker" type of trenching - I am sure Andy B can tell me the correct terminology!
Also on the corner of that trench and the main trench I have cut-away some of the sandbags. To make it easier to see the figures I wanted to make the space a little larger, and so that corner will feature a doorway into a small shelter, like the one in this photo:
Here is a photo of the final layout:
the trench looks a little wide, but I hope that when I have added the fire step it will look ok.
Peter
