Vector Resin Aftermarket ENGINE - replaces Hasegawa Kit Part !
This is my completed latest build
343 Kokutai , Naval Air Group -
Aircraft featured was Lt Takashi Oshibuchi ( six kills )
His Aircraft was wrongly featured as having 2 diagonal RED Stripes
on the Fuselage tail area , and is wrongly shown in the Kit Artwork
and also in the Kit Instructions by hasegawa
( always re-check your sources )
in fact the aircraft had White Stripes !
it is notable for the Montex masks which are used instead of
the Kit decals - plus you can then weather over these areas -
try doing that to a decal -
The National insignia and Unit Markings are the main benefits -
it used the Eduard etch , and a new item -
FUKUYA Brass Barrels for the 20mm Cannon and Pitot Tube
Another Notable addition is the VECTOR Resin Engine
( made in Russia ) - order from ' Parade Figures ' shop in UK
which is build as a kit in its own right , which replaces the single kit part
( which is just a sinlge part and looks like a Blob )
This Engine is so , so much more detailed and realistic -
it also has individual push rods made from Brass .
The Guns ( if you can see from my pics ) have a hollow end
plus so does the Pitot tube ,
another benefit is that everything is very strong as its all brass
anyway
hope you like - any comments ?
regards
anyway
regards
