Hello all.
I finished building my Airfix Douglas C-47 last year and have been putting off painting it because I am scared I'll ruin it due to my inexperience. Anyway, I finally decided that I need to stop procrastinating and get the job done, but I have some questions first.
The kit will be colored with the standard C-47 color scheme, OD on top and grey on the bottom. I'm wanting to do D-Day invasion stripes as well.
First off, I want to say that I don't plan on using model paints. For my other models, I have used normal rattle can spray paint (paint + primer), and they've turned out okay (See http://www.scale-models.co.uk/threads/lindberg-1-48-s-e-5a-my-first-build.25842/ for my first build). I feel it's silly for me to buy special paints just for models, since I am not really good at it yet and I don't want to waste money. Normal rattle cans of spray paint are so much cheaper and you get more.
So right now I have a light grey primer I was thinking of using for the bottom color, and I have an OD paint+primer that I used for the SE5A in the linked post.
Here are my questions:
- Will it be okay to just use a primer as the bottom color? I have done it in the past and it seems okay.
- How should I deal with the panel lines? Is pre-shading or post-shading better for the absolute beginner? (And will pre-shading work with standard rattle-can spray paint, since I can't thin it?) Post-shading is just like a pin wash, right?
- What should the order of paint be? If I do pre-shading, I would do that first, then I'd mask off and do the invasion stripes, then do the bottom (or the whole thing?) in the gray primer (and somehow make the rounded mask for the nose), then mask off and do the top in the OD.
- What is the best way to mask off the door of the plane so I can hit the outside, but paint won't get inside the fuselage?
- What are some good rattle can spary paint techniques? I always seem to get spots, or the paint goes on too thick.
- If I mess up on the paint (like using too much and blotting out panel lines) is there any way to save it?
