Wow Mike your so subtle.Well done, I am all for change, more active members. and more input.
But after having had a look around at some of the other forums (researching an old model article), this is by far the best forum for actually having the builders describe what they are doing even if it is just a basic old kit. The members on the other 'forums' seem to be only interested in turning out the latest all singing, all dancing, build it as fast as you can before the other stiff shirted, rod up the backside rivet counter. I actually read one blog where the modeller took the latest tank model which would have lasted at least a month and had it built in a week! But you could tell there was no reasonable research done.
Another is please do not turn it into a "I then glued this part to this part to this part to this part tozzzzzzzzzzzzzzzzz! As they do on another forum, there is not banter, and I am sure they all sit at their respective benches with the forum 'T' shirt on and latest rack of you tubers accessories behind them as they monotonously glue this part to this part to this part to this part to this part tozzzzzzzzzzzzzzzzz! I like life in my fellow modellers, banter, conversation, information passed back and forth, a bit of heat in the discussion - but at the end we are all friends and can laugh instead of glued part to this part to this part to this part tozzzzzzzzzzzzzzzzz!
Well that's my penny worth now go to go run the shopping trolly up someones leg, argue with the wrinklies, flirt with the checkout girls and hope SWMBO does not catch me - look out Sainsburys, I'm back......
Hoppity hip:smiling3:
