Operation Supermarine Walrus
Looks like the old Matchbox kit reboxed to me.Ive built a couple in my time along with the SMER 1/48 kit.I look forward to watching you put this one together.
Nice start Laurie, great little series of progress photos. Look forward to seeing your Walrus develop.
Thank to you both.
Not sure if it is an original Revell or Matchbox Dave. One thing the plastic is superb and so far the wings the gone together perfectly. Apart from a wet and dry with 1500 grit they need no more. No filling. Same with the floats absolutely spot on.
Looks like an interesting build Laurie! Will it eventually be ' on the water '?
Errr no Patrick. Suspended from my shelf above all the other 1/72. Saves room.
Interesting subject Laurie. And very nice start as well ;)
Lol. The spitfire was the exact opposite of the walrus. The spitfire was landbased-the walrus a flying boat. The Spitfire was all for looks- the walrus-well, it's name tells it all. BTW, that is an interesting subject, will be following this one
Wow! Organised or what! Very impressive, and an example to us all. Do please elaborate on that bird grit sanding. Also interested in the use of ultrasonic cleaner - I have one of those, due to an obsession with clean glasses!
Yes organised John. My outlook has always been tidy and you fit more into life or waste time searching for what you are after. Also the less like things in life do them first and enjoy much better the ones you like to do. Also running my own business multi tasking was essential as was orgnaisation.
Yes an erst.while member of this Forum taught me that one. Grit-Colin (go on guess his name) is just bird grit bought from the pet shop. Put it into a container, place the plastic bits in, shake it all about manually or on a dentists vibrator and the bits lose that shine and give a great finish for primer. I still wet and dry wings fuselage etc. but for small items especially ones it is impossible to sand this gives an excellent solution. Yu have to wash the bits thoroughly to get rid of the fine dust clinging to the plastic.
PS John. If you use, as I do , the sound cleaner for specs. and also after using GritColin make sure you get the grit out of the Sound Cleaner.
Not easy to see through frosted specs. !
\ said:
Yes organised John. My outlook has always been tidy and you fit more into life or waste time searching for what you are after. Also the less like things in life do them first and enjoy much better the ones you like to do. Also running my own business multi tasking was essential as was orgnaisation.Yes an erst.while member of this Forum taught me that one. Grit-Colin (go on guess his name) is just bird grit bought from the pet shop. Put it into a container, place the plastic bits in, shake it all about manually or on a dentists vibrator and the bits lose that shine and give a great finish for primer. I still wet and dry wings fuselage etc. but for small items especially ones it is impossible to sand this gives an excellent solution. Yu have to wash the bits thoroughly to get rid of the fine dust clinging to the plastic.
Hah! You learn something new every day. I shall also be watching this with great interest. It looks a lot better than the Revell 1/32 P51 I'm struggling with here - what a rubbish set of mouldings I have in front of me - but thats another story...
Ooh, an interesting kite, the old Walrus. :)
I like your detailed progress photo's, very informative!:cool:
That's coming along well Laurie, the crew are extremely good - naming them was a nice touch!
