Hi John, many thanks, I found I made the second window panel a mm out, was able to start all over again completing the port side real windows, this time glued in the panel then glued the clear panel in after, worked out much betty, pretty happy wish I had proper scale drawing, so long as the model is as close as I can get .Not an easy thing to replicate those angles Tony with out any plans, think your doing a sterling job .
Tony
