here is a trick I picked up that is useful for things that have small recessed letters. The Brembo lettering on this caliper is so small its a struggle to try and hand paint it but using trick has worked well for me.
started off with the basic color (needs to be gloss you can always hit it with dullcoat later if needed)applied and thoroughly dry
using red to 'fill' in the lettering and have lots of tape standing by
here the red paint has been allowed to pool over
then quickly apply the tape and pull the excess paint off the surface,might take several applications
after letting it dry you can touch up if needed and add wash,details ect.
hope someone finds this helpful thanks Trey
