Nice tree I know what a pain they can be to make
Thanks Jack. Just hope i don't mess it up when I paint it.Nice tree I know what a pain they can be to make
Thanks Polux. Not a bad start for my 2nd tree.Nice tree!!![]()
What are you using to coat the wire? I used cheap polly filler from the pound shop on mine but it tends to real off a bit when moved so I've just bought some Vallejo earth texture paint, should work better. You won't mess up the paint job. Paint it a dark brown, dry brush a few lighter browns and greys. Maybe even add a bit of green for a moss effectThanks Jack. Just hope i don't mess it up when I paint it.
Well on the last tree i did for my jeep diorama I covered it with milliput which worked really well. Also gives a chance to add some texture. Hopefully it goes as well as my 1st tree.What are you using to coat the wire? I used cheap polly filler from the pound shop on mine but it tends to real off a bit when moved so I've just bought some Vallejo earth texture paint, should work better. You won't mess up the paint job. Paint it a dark brown, dry brush a few lighter browns and greys. Maybe even add a bit of green for a moss effect
