perspex sheet
hi all im new here im looking for any info on building my own display cases with perspex sheet and wood base's will it work out cheaper then buying ready made one's
thanks in adavce
Martin, I'd be surprised if you didn't save significant amounts. An 1800x900mm sheet of 2mm clear acrylic sheet is just £15.99 at Wickes Building Supplies,which gives you enough to build several large cases. Perhaps Wickes also sell the solvent, which I haven't costed just yet.
thanks. it just means a bit of my time building the case's most of the models will be tanks, jeeps , aroumr many to start with just have to get back in to modeling again
also have a look in the modellers resource directory there is a company called adhesive brokers ( www.adhesivebrokers.co.uk) who stock all kind of glues and solvents...... i am sure they will source tensol or other brand of acrylic adhesive/ solvent
Dichloromethane (sold as Plastic Weld, in the U.K.,) will do the job.
Edgar Brooks
plastic weld often contains MEK too, so be careful - it will bond acrylic but it can mark the finished surface too...
display cases
Hello,
I can make display cases, that wont cost the earth!
All made by hand, no milling machines used.
I use chloroform. it is the best way to join perspex.
\ said:
hi all im new here im looking for any info on building my own display cases with perspex sheet and wood base's will it work out cheaper then buying ready made one's thanks in adavce
difficult to get hold of chloroform now, you can sometimes get it via chemist, but its not commonly held now by most high street chemists.......
I make perspex pots for human anatomy specimens, in a london medical school and pathology musuem. You can't buy chloroform over the counter.
Then the big question is can you buy it 'under' the counter ;-)
A more serious question or two.
How does chloroform work as an adhesive, is it a solvent.
How do you use it with out falling asleep...................................................
