Peterairfix's Northrop F-5A Freedom Fighter
peterairfix
Time to throw my victim into the ring and like most kits just the four pots one glue and brush and a whole silver aircraft to paint.
This one comes with additional flash and ejecter pin marks Galore.20190401_162900.jpg20190401_163403.jpg20190401_163534.jpg20190401_163547.jpg20190401_163608.jpg20190401_163620.jpg
Hi Peter
You are welcome to that :rolling: The flash is bad. I shall certainly follow this.
This one will give you a lot of work Peter, good luck with the flash and bent Sidewinder.:thumb2:
Hi Peter looks like you have got your hands full with this one, good luck I'm sure you will sort it out.
Pete.
Now the fun has begun the poor pilot looks a bit blue the two fuselage halves went together ok but look at the nose got some sanding to do.20190402_142022.jpg20190402_142031.jpg
A tough one. Good luck. PaulE
Both wings on air intakes fitted terrible lots of sanding done the nose is a bit better and finally got some paint on but it's going to take a few coat's.20190402_185028(0).jpg20190402_185006.jpg
Nice start Peter, it looks a lot like the first build I ever did already, but it was a Skyhawks.
Another couple of days and another couple of coat's of as it needs a good day or so to dry
Peter,
this GB of yours really makes you appreciate the normal tools of making models. It also shows the problems of a single overall paint coat, and a small brush...........................
Hi Peter
The fit of that nose is shocking. Are you sure it's actually from this kit :tongue-out3:
Well done with the silver. I still have that pleasure!
The basic construction is complete and considering is a 1966 mould it shows there is not much more that I can do other than tidy up the paintwork as it does look like it was built by my 12 year old self.20190405_162202.jpg20190405_162150.jpg
Hi Peter
Well done. I hope my silver goes on as nicely.
