Some of you might recall that I made a thread a while back called BAC Spitfire XIV which went a bit tits up when I found out I had the wrong Mk of spitfire. Well Out of that I did get loads of good info about the real Silver racer Spit. It was a Mk 21 and was one of the few with a six blade contra prop.
A while ago I got hold of a Mk 21 Spitfire from Planet Models. An all resin kit....(gulp).
A few days ago, I got hold of a six bladed contra prop from Heriatage Aviation Models. It was a part of a conversion set so I had to pay the princly sum of £12.50 for the set just to get the darm prop!! I will just say that the planet Spit was not that cheap either... 'nough said!
Any ways. I got the urge to start on this while trying to figure out what the heck to do for the next group build.....
Enough waffle her is the bit you will skip to anyway.
View attachment 42588 View attachment 42589
First off here is the very solid box made 100% of corrugated card. The wing and the fuselage halves each in there own bag, the small parts in two bags inside a larger bag. So its a very well packed kit.
View attachment 42594 View attachment 42593
The wing is one part, none of that typical one bottom part plus a top left and top right to get lined up and fit. Very nice detail and only a light clean up.
View attachment 42596 View attachment 42597 View attachment 42595
The Fuselage is also very clean and crisp with just a hair fine 'flash' around the cockpit opening. Strait and flat and all lines up. The detail is very nice both inside and out.
View attachment 42590 View attachment 42592 View attachment 42591
The small bits are also well cast. some of them are very tight to the casting block so will be fun to remove. The instrument panel has detail which is maybe on the light side and will be a challenge to paint.
Wheels/tyres two sets, four and tree spoke. Some one in the packageing department made a boob. Some how I have three exhaust stacks but no control stick- I have sent them an e-mail so will have to wait and see what they say/do. Otherwise I will have to scavenge one from a Tamiya spit!!! Bit of a pain as the pit is the first thing to build and paint. I 'spose I could drop a stick in it later if the need arises.
I also need a harness though so I might just have to wait.
