Pre-shading Metallics
Vaughan
Hi has anyone got some advice on how to pre-shade panel lines when using metallic paints?. I have given it a go using black but all that happens is that as soon as you spray over the black it disappears. Will I have to just rely on post shading using a wash?
Vaughan
Only way you can do it is post-shading. Add a drop of black enamel/acrylic to the metallic paint to make it a shade darker then go over the panel lines afterwards.
What paints are you using Vaughan?
I experimented pre-shading Alclad and it didn't produce the desired effect. I was very dependent on the angle of viewing,varying form completely invisible to a patchwork quilt. I use different shades or tint as per Allyne's advice above.
If you use buffable metallics, once the paint has cured polish the surface you will get a 'pre-shading' effect as the paint in the grooves and dips will not be buffed up.
the Gunze buffables a great for this.
I pre-shaded my EE Lightning using Tamiya paint, see postings #55, #56 and #64 on the link below.
http://www.scale-models.co.uk/planes-helicopters/11101-e-e-lightning-f6-1-48-airfix-6.html
\ said:
If you use buffable metallics, once the paint has cured polish the surface you will get a 'pre-shading' effect as the paint in the grooves and dips will not be buffed up.the Gunze buffables a great for this.
Barry are Gunze buffables paints easy to airbrush and would they require thinning?
vaughan
Vaughan.
I have sprayed using a 0.4 needle without thinning without problems. The Dark Iron (great for engines) and Stainless to be specific.
Thanks guy for the info. Will have to have a think on this one and decide which way to go.
Vaughan
