today i tried my model r/c model pt boat on the water for the first time.
i was very impressed with it as it sat perfectly in the water and cruised very well at slow speeds but on high speed or full throttle the boat tilted in the water as if it was going to roll.
does anyone no any possible causes for this ?
the model is 31'' long (1/32nd scale) and has a 540 35 turn motor with direct drive and a p45 2 blade prop
the model i have built can be viewed here The ELCO PT boat scale electric model boat
i have followed the build perfectle apart from making the motor direct drive and i have finished the hull with sanding sealer rather than tissue.
and suggestions are very greatfull.
thanks in advance
mark
thanks in advance
mark
