Hi all.
I was asked by a fellow modler to mould a Bell "cripple two" for a raptor 50.
These moulds I have are actually a little big for a standard 50 size heli, but not to worry....I just remove 2 " off the tail boom.
This one in # 2 out the moulds as I use #1 for tooling prototype.
I use aircraft glass and epoxy resins for the layups. #1 is a BIG heli and came in at 1,01kg.
Hoping to get # 2 a tad lightler.
There was no top cabin mould so I had to make a plug for the mould I made from carved foam and a stagering amount of filling and sanding!
This model will not get retracts, but have fixed skids like the 222 UT. If I can't find off the shelf skids I will have to make a mould for them and use carbon for stiffness.
The layups I did today will hopefully be joined tomorrow.
All I can say is that to do the glass work inside those sponsons is not fun atall :-(
Theuns
Theuns
