Resin 3d printing ,
monica
Hi all i have use of a LD-002H ,resin 3d printer,as my friend got one with a bigger build plate,
but my problem is im not under standing the setting in chitubox for the elegoo water washerable resin ,as it defaults to creatty resin
and if on the last page do i need to alter the resin setting ?
if anyone who dose or is able to give some advice and other help would be great
Ooh, sorry can't help there but a friend here is having a great time with his 3D printing. Every software is different.
hi the softwear is so different from cura to chitubox ,
Hi Monica
I'm not familiar with chitubox, you are probably better off checking out a chitubox users forum https://forum.chitubox.com/
Good luck
Neil
hi, ta i will have a look into it,just so different for me the useage of it
Looking to get into Resin Printing personally so have been following some great users on youtube / facebook etc
look for 3dprintingpro and unclejessy on youtube.
The answer I usually see for each new resin you use is to do a test print , there is a clever system built into UVTOOLS , info @ https://github.com/sn4k3/UVtools/wiki/Calibration:-Resin-time-finder?
resin profile info for chitubox @ https://forum.chitubox.com/?thread-268.htm
hi i have had a look at new user for it ,but that part of setting and changing the resin setting they always just kind of skip over it and on to other things,
i will look into this ta
https://docs.google.com/spreadsheet...b_Td6EGLyGHeJ8bY6yyQxs7IM9fRJ0fRgohqtTfI1hLUI == a table of resins and their starting settings, you will need to fine tune for your individual printer.
answers given to someone else using your printer and elegoo water washable resin @
Hi,Gary thank you that will be of great use,and a very good starting point ,
that maybe there is a scratch or something that the resin is sticking to the TFE scream but kind of lucky there on the edges so you still have
a lot of scream left, it is a hole no new process to get use to ,Im finding the setting the most different from cura,but just need to get it started
and lean as yougo along, i think the biggest thing is why chitubox just has the defult setting
