It depends a lot on the manufacturer, but in general: yes. It’s an entirely different material, and you can’t really work with resin in the way you would with plastic.I have my eye on a resin kit but, I've never built one. Are they more of a challenge ?????
Mainly, you need superglue and a razorsaw (that is not a saw shaped like a razor blade, but a thin, fine-bladed regular saw intended for modelling, among other uses), and for large, heavy parts, epoxy glue and a sheet of wet-and-dry sandpaper stuck to a flat board. You can’t glue resin with normal model cement, because it won’t dissolve in it, so you need superglue or two-part epoxy (use the latter when strength is needed). The saw is needed to separate some parts from the sprues they’re on and the sandpaper is to make sure they’re flat, though you should try to saw and sand resin as little as possible because the dust is harmful. Always sand it wet, for example.do I need a whole load of new kit to work with it.
![P1000212_zpsfzzlg14k[1].jpg P1000212_zpsfzzlg14k[1].jpg](https://www.scalemodelling.co.uk/data/attachments/51/51120-524bfb9eecb71a54b30228c91ec3ea40.jpg?hash=VR9XM6a1H0)
What kind of kit are we talking about? Tank, aeroplane, car, figure, spaceship, something else?Thanks for all the input people. I think I just need to bite the proverbial bullet and take a shot at one.
I’ve got that Tamiya saw too, and don’t much like it — maybe I should have mentioned it the other week in the thread about tools you wished you hadn’t boughtOne thing I would say is that you don't already have a good razor saw, you should certainly invest in one. It really is the best tool for releasing the parts from the casting blocks. I have an old Tamiya one with two blades, one coarse and one not so coarse
I couldn't agree more. I have used it, but it's a crude tool for a rough job!I’ve got that Tamiya saw too, and don’t much like it —
Same, if I’m honest — unless the kit is bad enough that almost everything needs work, then it gets to be a chore. I’ve got a Schützenpanzer Lang by Elite Modellbau, and I’ve not had the courage to start it — that company can probably cast a solid tank hull, warped …I rather like a resin kit, to be honest.
You can always fill your mistakes with cellulose car filler (stopper) as used in car paint preperation, but do it in a airy environgment and store outside in a shed untill dry, then wet and dry sand in soapy water.Thanks for all the input people. I think I just need to bite the proverbial bullet and take a shot at one. If I screw it up then I'll just keep qiet about it and move on. Otherwise I'll keep you all posted on what I end up achieving.
Take care everyone and stay safe.
Peter
