Revell 1\32 spitfire Mk lla with Eduard pe
peterairfix
That's a busy PE sheet Peter. Looking forward to seeing your results with the airbrush on this build
Hi Joe
I will follow this with interest and I'm sure to pick up a tip or two to help with my slightly smaller Eduard kit.
Hi Peter
Good progress. Interesting to see the extra level of detail there is in 1/32 compared to 1/48. I know this is enhanced with the Eduard PE but I think that slight increase in scale really pays dividends. Mind you it could also show up faults easier - not that I can see any in your build :smiling5:
Looks good Peter...love the Bakelite seat colour....
Tim
Hi Peter
Glad the two fuselage halves went together nicely. Filling and sanding and then reinstating panel lines and rivets is not fun :crying:
Will be following this one closely as I have the same kit in my stash so will base it on your build I to will have eduard cockpit pe for enchanching the detail
Regards
Colin
Peter
Wonder build and detailing. Not too sure what happened on your other two attempts but this one looks great. Keep it comin:thumb2:
Peter
The last two attempts were using rattle cans and brushes and at the time I didn't know much about weathering.
Nice build sofar.I did thos kit not to long ago. Appart form some fit issues it was a nice kit.
Just look out for the rear part of the glazing behind the Malcom hood, it was way to narrow on my kit, the wingroot als was not to good. The wingtips also need some carefull fitting, maybe gluing to the wings before joining top and bottom will solve this
The decals went down nicely though :-)
Allot has been said that the ailerons being fa bric is incorrect for this plane however I have read that for a 1940 to early 41 plane they can be correct as replacement metal ailerons only started getting to Sqn's by mid 41 IIRC.
Here is the one I builtView attachment 302140
Theuns
Some more work done today this time I have the two halves joined with no filler needed and the same with the main wings no filler needed just the sanding of the joints.
Plus I have a few other bits painted.View attachment 302230View attachment 302231
Hi Peter
Coming on a treat. Most interested in how you have masked up. I have that ahead of me and having never done it before your photos are really appreciated. I presume it is BluTac and Tamiya tape?
Yep Tamiya tape and blu-tak but it only seems to work with the bigger scales well for me anyway
