Revell 1/48 B-25J Mitchell “Jaunty Jo” - My First Big Build
Looking at the photo's I think you're doing a fine job on your first build - no not an easy kit, but not impossible and man, what a cool subject.
As far as putty goes, I've used loads over the years, Revell's Plasto basic putty, and perfect plastic putty (PPP). The Revell stuff is much like your Tamiya putty although I find it easier to sand - great for seams and what-nots, and the PPP is useful stuff as it's water-based and can be removed with a damp cotton bud whilst still wet - it's great for fine cracks or gaps around wing roots and canopies etc. To apply both I use generally use a small spatula, cocktail sticks, cotton buds - whatever does the job.
When sanding I have a range of grades of sand-paper, some wet and dry, starting with a coarse and working to finer - this helps with scratches etc. I also have a set of small needle files which really help.
You're doing a great job of re-scribing the detail for your first attempt - I'm not much better and I've been doing it for years. When it comes to replacing the lost raised detail there area few ways people do it but I've never mastered them - I just generally scribe the missing detail in, run some Tamiya Extra thin down it and keep the sanding to a minimum. It looks okay under paint. You also might find this stuff useful for scribing lines, it's called Dymo tape and it's for label printers - it's sticky and plastic, so unlike making tape you can run the scriber along it. (excuse the amazon link).
Looking forward to seeing more!
(oh and the nose weight someone mentioned is a good idea if you have room to add any in).
Oh and don't worry about Brush painting - airbrushes are great (and by all means get one) but you can still get a decent finish using brushes and spray clears - feel free to PM me if you want any advice.
Thanks so much for taking the time to write such a detailed reply, Darian! Really appreciate all the advice and encouragement!)))
That Perfect Plastic Putty sounds very interesting, especially the fact that you can clean up the excess with a damp cotton bud. I’ve added it to my shopping list for future experiments!))
And thanks for the tip about Dymo tape! That’s pretty much exactly what I’ve been looking for. I’ve been making my own guides from strips of old plastic cards, so having something that’s both rigid and self-adhesive sounds much more convenient. That’s going on the shopping list too! 😂
I’ve actually just tried the Tamiya Extra Thin trick on my rescribed panel lines, and I’m really pleased with the results! The lines look noticeably cleaner and smoother now.
As for the nose weight, I’m definitely going to give that a try as well. I’d much rather have the Mitchell standing on its own three wheels than relying on a little ladder to keep its tail off the ground! 😄
Thanks again for all the helpful tips!
And thanks for the encouragement about brush painting too! 😊
I definitely want to try an airbrush at some point, but for now I’m quite enjoying learning how to paint with brushes. There’s still so much for me to experiment with!
I’ve already bought some regular clear varnish that can be applied with a brush, but your suggestion about spray varnish actually sounds like a much better idea!
I’m planning to experiment with different weathering techniques, such as pigments and using pastels to create exhaust stains, soot and oil marks. And I imagine a spray varnish would make it much easier to seal everything without worrying about smearing all that hard work with a brush! 😄
It’s really encouraging to hear that you can get good results without an airbrush.
And thanks so much for offering to help! I might just take you up on that when I get to painting the outside of my Mitchell! 😄
